The dipped lights on my 2001 model Xsara are very poor and the do not seem to give much luminousity which I find to be a danger when meeting oncoming traffic on country roads which I normally use.
Is anyone else having/had a similar problem with the quality of the dipped lights on thier Citroen or specifically Xsara and if so can anything be done to improve the situation that doesn't impact legality/roadworthiness and blows fuses!
Thanks.
Improving the dipped lights - 01 Xsara
Father Ted
reblack68
The lights on the C5 are awful too. There's plenty of light there but you can't see anything by it. Plastic just isn't a suitable material for headlight lenses.
You could try buying Osram Silverstar/ Nightbreakers or similar bulbs. They are standard wattage but a bit brighter. Standard bulbs from a reputable manufacturer might help too, I believe a lot of nameless bulbs aren't really up to the job.
Richard
Care of a 1994 205 D.
DickieG
- Monaco's youngest playboy
- x 38
I don't know if this does apply to Xsara's or C5's but it certainly does to S1 Xantia's so its worth checking as it only takes a couple of minutes to do. Turn the headlights on and connect a volt meter across the battery terminals, note the voltage then connect the volt meter to the wire at the back of the headlight bulb and earth and compare voltages. If there is a great variation between the voltages (1 volt being great) it shows that somewhere along the line the lighting circuit is losing current, this can be easily remedied by fitting a relay to the lighting circuit. I did this to the Activa that Jim now owns (pardon the pun) but the before and after difference was literally like day and night
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Timmo
- x 168
A relay in the system can make a big differnce, also worth checking earth points around the lamps, spent the day on the bx cleaning all theearths up, made a big difference!
The simplest wwy is to bung in some higher wattage bulbs to get a big impovement, als worth checking the lense on the lamp as often thry can take an opaque turn, a light wet and dry with 1500g or finer and polish up can also help,
If you want superb lights then get a decent HID kit, not the cheapy chineese ones as the balast packs dont last, but a good set from a uk supplier around the 6000K output to not go too blue and chances are youd very rarely use high beams! Annoys the pants off every other road useras they are Bright but aproper hid kitbis an amazing difference!
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
Father Ted
