Xantia rot spot
Xantia rot spot
I opened the back door on my xantia and think i can see signs of rust towards the sill, I would like to save the area, so I looked at the bungs in the wheel arches and see they are looking past ther best, is there a recomended way to reseal the aea permantly to stop water ingress ?
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
It has been covered before. The area that has the common rot trap cannot be reached through the bungs.............spray through bungs anyway.
To reach the usual rusty area I took a seatbelt mounting off and drilled through the hole This lets you in to double skin with a can of waxoyl or a spray chain grease with a straw on it
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Yes, but before you start spraying with sealants, you must make sure the area is dry, especially in the seams in the steel panels and then use a nutrealizer or rust inhibitor, like Jenolite. Once that has dried throughly, then spray with a sealant like Waxoyl.
If you do not dry the seams, the sealant will just trap the moisture and allow it to carry on delaminating the steel, thereby enhancing the corrosion.
H
H
