ABS ring on brakes
KennyW
x 163
ABS ring on brakes
Unread post by KennyW »
Hi all,
Just changed my outer CV joint and now the warning light for the ABS has come on at the dash.
What has caused this problem :?:
Suggestions please :?:
Kenny
PS My new car has been previously living in Plockton, west Coast of Scotland and the outer CV joints are very rusty me thinks sea water has caused problem.
PPS Plockton is on the west coast looking over to Skye (Stunning views) :wink:
C3 1.4 petrol (SWMBO)
x 1483
Did you fit the right size CV joint? There are 2 and the later ones are larger. Might just be that messing with the hub has been enough for the ABS sensor to say enough is enough. Lexia session required...?
KennyW
x 163
Richard,
I don't think so my brake caliper says bendix and that's the one i fitted.
This is where i bought it from
www.jandrcvjoints.co.uk
It states it is for my Xantia.
The brakes work and the car stops really does anything else matter :!: :wink:
Kenny
P.S. Jim it maybe worth putting this site in our useful info for driveshafts,ball joints CV joints etc.
Xantidote
x 5
Unread post by Xantidote »
Plockton - ah yes, a very pretty place. Was there 1 night a couple of nights ago :D :D
Martin
1995 Xantia TDLX (deceased :( )
KennyW
x 163
Richard,
I was think of a lexia session.
Another thought what difference would 1 new and 1 old Abs ring make to the sensor.
Kenny
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Pop a wheel back off with the car SUITABLY SUPPORTED!!
Then check the gap between the sensor end and the ABS ring! The gap should be NO bigger then a piece of paper between the sensor Tip and an ABS ring tooth...
Chances are, despite them being "vurbually" correct for your car they will be smaller CV joints...
Ive seen this on a 1997 P reg TD Xantia, replacment CV's were fitted but they were smaller ones from a 1994/5. The ABS light went out on startup, but came on once moving...
Paul
A very sad...
1994 XM 2.1 d auto
KennyW
x 163
Paul,
I was thinking about all the work I have done on the car and to replace the front discs I had to remove the ABS sensor.
If this is not fitting correctly this would cause the fault light to come on ie it's too far away from the abs ring.
citroenxm wrote: Then check the gap between the sensor end and the ABS ring! The gap should be NO bigger then a piece of paper between the sensor Tip and an ABS ring tooth...
Paul
Kenny
citroenxm
Fallen Hero
x 70
Yes precisely...
Does it go out though, on startup???
Paul
A very sad...
1994 XM 2.1 d auto
reblack68
Unread post by reblack68 »
The Mk2 Xantia's ABS light doesn't reset on startup like the Mk1's did. Even when the fault is fixed the light will stay on until the car is driven over 20mph.
Richard
Care of a 1994 205 D.
citroenxm
Fallen Hero
x 70
Reblack68
Oooerr thats a point I forgot, but thats also the same for P reg Xantias aswell.. I did a sensor last week on one, but had to go for a drive to put it out.
Paul
A very sad...
1994 XM 2.1 d auto
KennyW
x 163
Paul
The light stays on all the time.
Kenny
citroenxm
Fallen Hero
x 70
Sounds like after a Hub swap the sensor has gone, possibly a break in the cable...
Paul
A very sad...
1994 XM 2.1 d auto
KennyW
x 163
Okay, Its going to be a lexia session.
Kenny
