Hi
the engine management light on my 2.0 hdi van has just come on, the fault code is PO220 TPS/pedal position sensor/switch B circuit malfunction. What is the TPS and what is the best cause of action to resolve ?
Fault code PO220 ?
DickieG
- Monaco's youngest playboy
- x 38
Hmm, not entirely sure if this applies to whatever model your van is but I recently dealt with a similar issue on a C3 HDi where a common fault is the connection socket behind the glovebox for the accelerator where the loom is extended across to the offside for the RHD conversion. The remedy was to cut off the connection block and solder the wires in the correct order and cover the new joint in shrink wrap. So far the fault has not re-appeared.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
johntom
Also today the van is giving problems starting. Not sure if they are connected issues but the van started ok from cold but after being run, then left for 10 minutes it would only fire up for a second before cutting out. Each time i turned the key it fired up and ran for a second or two, on the 10th try it started and kept running ? When i stopped again after a further 6 miles it did the same again ?
