I've got problems starting my Xsara '98 XUD 1.9td. The glow plugs are not being activated by a turn of the key. Instead I hear a click from the passenger side of the car. The glow plug dashboard light doesn't come on.
After a bit of faffing about turning the key, the light will come on, glow plugs do their job, off I go.
I'm thinking the problem may lie in the ignition barrel – it's been a bit crunchy in there from sand since a beach holiday in Cornwall, though that was a month ago, and the problem has only just begun.
Or would it be the glow plug relay? Thanks in advance of any help...
xud ignition fury
Ralph,
Very easy to prove...just disconnect the ign feed from its terminal on the glowplug relay and replace it with a temp feed you've made from and old switch in the car.
ie Obtain a switch, fuseholder and several feet of wire. Make a connection to the battery +ve with an aux fuseholder, take the wire into the car to a simple extra switch somewhere handy. Take the feed back from the switch to the terminal on the relay the original ign wire came off.
Now you have full manual control to prove where the fault was. On older cars, where the glowplug position within the ign switch was the fault, I've known folks leave it like this to avoid changing the ign switch.
David
David
Ralph,
Had a similar problem on my ZX 1.9TD recently, sounds the same, turned out to be the immobiliser. If you've got one it's worth checking. In diesel cars there's not alot you can fit an immobiliser to, in my case the main circuit was working but the bit connected to my glowplug circuit wasn't, If you've got a problem with an immobiliser I'd suggest an autoelectrician because they're (as designed) not easy to play with!
otherwise as previously suggested it sounds like the relay.
- Contact:
The later (post '96 i think) diesels have a POST heat relay on them (not sure where its meant to be located, mine is duct taped to the main glowplug relay). This could be at fault? i think the main relay will still work if you unplug the post heat relay from its holder, may be worth a shot? cheaper than a main relay i suspect!!
