MOT....
x 1504
MOT....
£400 For the Picasso. Ouch :twisted:
New track rod end end, ball joint (so new arm as not separable on the Picasso) and spring - all on the same side. And then when he took the spring off the damper ejected the piston :shock: so it had to have a new damper too. Tracks a bit straighter now, and it's quieter too.
Oh, and the Xantia has blown a big hole in the main exhaust pipe at the rear box joint, so I have that to fix now. At least I should be able to fit the (cheap, phew!) repair pipe. It will need new tyres on the front next month too :cry:
Never stops does it??
