Tyre sizes
XantiaDaveEire
x 4
Tyre sizes
Unread post by XantiaDaveEire »
The tyres that are currently on my car are 185/65/15 and the tyres i'm looking at getting are 195/65/15..
They would fit ok wouldn't they? :-k
There wouldn't be any real differance good or bad ?
Dave
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
davetherave
x 4
Unread post by davetherave »
They will fit fine, i have them on mine I think exclusives had them as standard, though am not 100%
But you are not alowed to put wider on the front than back, so either replace all or but the 195s on the back.
Dave
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
XantiaDaveEire
x 4
davetherave wrote:They will fit fine, i have them on mine I think exclusives had them as standard, though am not 100%
Dave
Cheers man,I'll have to go for the 4 tyres then
x 1504
Will give you a speedo error of about 5%.... You could go for 205/60s as these are the same rolling diameter as 185/65. Note that insurance cos these days may take this as a mod and refuse to pay out in the event of a claim :twisted:
Never heard you cannot have wider tyres on the front than the back - certainly MOT fail if not the same on the axle - but I could be wrong :lol:
XantiaDaveEire
x 4
RichardW wrote:Will give you a speedo error of about 5%.... You could go for 205/60s as these are the same rolling diameter as 185/65. Note that insurance cos these days may take this as a mod and refuse to pay out in the event of a claim :twisted:
How does it give a 5% differeance ? :?
davetherave
x 4
The 195 65 15 tyres in place of 185 65 15 will give an error of 2.1% too slow.
http://www.miata.net/garage/tirecalc.html
meaning at 60 its actually 61.3
Dave
GPZ500s
XantiaDaveEire
x 4
davetherave wrote:The 195 65 15 tyres in place of 185 65 15 will give an error of 2.1% too slow.
Dave
Cheers Dave,i think i'll just stick with the tyres i was originally going to get then :)
Ross_K
x 110
Re: Tyre sizes
Unread post by Ross_K »
Citroenmad
x 110
Unread post by Citroenmad »
205.60.15 is an original Xantia tyre size, as used on Activas and Exclusives etc. 195.65.15 is not an original size but it should be fine to use. As said, your speedo will now under-read, however Xantias often over rear by 5mph, so you should still be within tolerance.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
vince
x 13
Unread post by vince »
im currently running my xantia on 195x65x15's and will be going back to factory standard ones next.
The only problem i found was i had to lose a couple of mudflap bolts as they rubbed on full lock. no big problem...
I prefer the look of the "normal" size tyres :wink:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Early Dees had wider front tyres than back; 165-400 compared to 155-400.
handyman
Unread post by handyman »
And Cx Mk1s, 185x14 on the front and 175x14 to the rear! :shock:
H
addo
x 95
If we keep this up, Jim will create an "Olde Pharts" subforum for the over-40s to reminisce in. :shock:
handyman
And what's wrong with that? :taz:
H
