Hi, I'm interested in replacing the factory fitted head unit (a CD/RDS radio with flap) in an HDi SX, which I believe is a Blaupunkt, with another non-Citroen Blaupunkt unit (with MP3 and Aux functions) - anyone with experience of doing this? Will I need an adapter cable fo the steering wheel controls or will any Blaupunkt unit plug directly into the existing cable?
Xantia Series 2 (2000) - fitting Blaupunkt radio/CD player
- madscientist
- Ross_K
- Lexia Available: Yes
- My Cars: 2009 Citroen C5 VTR+ HDi 1.6
2004 Toyota Prius
2004 Alfa Romeo 156 1.6 Twin Spark - x 110
A Blaupunkt should have ISO connectors so it should plug straight in.
Sometimes you need to swap the permanent 12V and the switched 12V around on the loom.
For the steering controls, you obviously need a head unit which will take a remote input - not all do, so double check before you buy.
You then need a Citroen -> Blaupunkt interface cable for the remote. An Autoleads PC99-X09 with a PC99-BLA patch lead should do it.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Re: Xantia Series 2 (2000) - fitting Blaupunkt radio/CD play
Series TWO Xantias use Clarion! The ISO connection are a Standard type for Power and Speakers, however, you will need a conversion lead for the steering wheel controls...madscientist wrote:Hi, I'm interested in replacing the factory fitted head unit (a CD/RDS radio with flap) in an HDi SX, which I believe is a Blaupunkt, with another non-Citroën Blaupunkt unit (with MP3 and Aux functions) - anyone with experience of doing this? Will I need an adapter cable fo the steering wheel controls or will any Blaupunkt unit plug directly into the existing cable?
Series ONE Xantias used Blaupunkt in SX, VSX and later Exclusive V6 cars only.
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
