Xantia engine rattle
PicassoPigeon
My Xantia R-reg 97 1.9TD A/C makes a rather loud rattling noise at low revs, or idle speed. The noise disappears when revs go above 14-1500 revs. It's a very deep grumbling sort of rattle from the inside of the car, and on the outside it has the same deep grumble, but with a "pocket full of change" tinkling as well. Apart from this noise the engine runs perfectly fine. Does not overheat, chug or otherwise play up. It came on very suddenly. Anyone know what could cause this noise?
David W
When you say inside the car do you mean inside the engine compartment?
Is it possible to pin down a rough area for the noise?
Not something to do with the aux belt such as the belt breaking up, failed idler pulley, failing hydraulic pump, failing a/c comp or worse of all a loose crank pulley??
Or perhaps timing belt/tensioner problems?
This could be the early warning of something terminal so it needs looking at asap.
David
David
PicassoPigeon
David W
PicassoPigeon
Jonesy
PicassoPigeon
i have found a bolt missing from the hydraulic pump where it mounts onto the engine, with my head near by the noise is more loud here. could it just be a case of this missing bolt, or could it be the whole pump that is on its way out. everything still works fine on the car even with the noise problem.
thanks for your help so far, will go and get a new bolt and try later.
PicassoPigeon
