Has anyone done one of these?
From what I gather you have to remove the back of the seat to route the cables. Any idea where the clips/fixing points are on the frame of the seat?
Mine are leather and I really want to find out more before I start pulling things apart.
The kit I would be trying to install is an XTRONS HD903. I'm sure I can sort out the wiring and the install of the headrest into the seat. It's just running the wires down through the seat that is causing me concern.
Any suggestions welcome!
Many thanks
Headrest DVD installation in C5 exclusive 2.2 2003
chasqui
- x 3
chasqui
- x 3
dave2011
fitting these things are pretty easy to do but you would need a 12v and earth feed routed under the seats with enough slack to compensate for if the seats where adjusted.the kits usually come with different sized poles to slide them into the seats.also the poles usually adjust width wise to fit various cars.
