Refurbishing alloy wheels
handyman
Unread post by handyman »
I am about to launch into tidying up a couple of standard Xantia alloy wheels that have a little corrosion. You know, flaky paint and bubbling corrosion.
Anybody know what the paint colour is? Any recommendations for types of paint?
I am stripping off the laquer and top coat, and will reprime with a self-etch aluminium primer and probably finish with a urethane glaze top coat.
I have a couple of tins of yatch enamel that will be man enough for the job, but the sliver colour is just not right, too bright. Any suggestions?
Handyman
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Original finish appears to be an epoxy powdercoat.
Your best bet for a refurb might be epoxy/urethane primer then a washcoat (wet on wet) primer followed by basecoat and 2K clear.
