I want to throw out a general question regarding the carrying of weight in boot over extended period.
I am using car to carry reasonable bit of weight - cant quantify just yet - in trunk. The items will be more or less stored permanently in car and that would mean over night and at week ends when car not in use that the weight will be there. Would this have any effect on the cars general suspension/hydraulics over an extened period?
Car would be parked up on normal height position.
Any thoughts?
DublinChris
xantia effect of load in boot over long periods
DublinChris
DickieG
- Monaco's youngest playboy
- x 33
- x 1240
Providing that the suspension comes up at normal speed and doesn't struggle you are not exceeding the acceptable weight and so shouldn't have a problem.
As Dickie says it will increase the load with a corresponding increase in wear. This will be one time when you are at an advantage if the suspension drops, it will take the pressure off the spheres.
I have carried half a ton or more in my XM estates without any apparant problems, if the suspension is in good order I wouldn't worry.
citroenxm
- Fallen Hero
- x 70
- x 5688
f00lzz
Me too in a V6 XM Est... Two large press tools, transferred to the wife's Mondeo Estate and just one tool had the Mondeo on it's knees.. brilliant XMPeter.N. wrote:Providing that the suspension comes up at normal speed and doesn't struggle you are not exceeding the acceptable weight and so shouldn't have a problem.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
DublinChris
I remember back in 80's
- x 1240
That's reminded me. When I sold my last CX a DTR Turbo Safari I sent with it all the spares I had including an engine and gearbox, four lads came to pick it up and by the time they had climbed in as well it was touch and go whether the rear suspension would get off the ground but that's the only time I've seen that happen.
