My 2001 2.0 Hdi C5 suspension doesn't seem to be working anymore. After not driving it for a week I jumped in and promptly broke the bottom of the rear bumper on a speed bump. The front raised once when I used the adjusting switch but now there seems to be no movement at all and I haven't got a clue what to do. Any help please.
Suspension Woes
Clogzz
- x 40
carpy
- x 5672
Clogzz
- x 40
Was here, picture on second page:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=35720
carpy
Many thanks for the replies. Can't look at anything today as it's absolutely pouring down and the car is outside. I have noticed that when you unlock the door the pump noise and suspension movement is no more. Nothing comes up on the dash warning panel as well. From reading the other post either the pump is getting no power or is broke. Can't understand how this can happen as it was working when the car was parked up.
Fed up now.
Fed up now.
cachaciero
- x 9
There is another possibility, if the BHI believes that both axles are "higher" than demanded the pump will not run. Now this implies a failure of both height sensors which is somewhat unlikely however the reference voltage that feeds the sensors may be fed by a common bit of wire.
Another possibility is the center console "low" switch permanently made, again if max low is set the pump will not run.
Finally the BHI has two distinct parts, the pump which is fed by the MAXI fuse which you have already checked and the logic / ECU part which I believe will have it's own fuse if the ECU is dead i.e blown fuse there will not be a signal to energise the pump. Sorry don't know where the second fuse is at the mo.
The pump can be energised separate to the logic.
On the pump connector there is a heavy contact which has 12V from the maxi fuse and a lighter contact which is the logic control input to the pump, if you connect 12V to the heavy terminal and 5V to the logic input the motor should run.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 5672
cachaciero
- x 9
Yes I think you are probably right re the indication not so sure that speed would overide the "lower" switch if permanently selected, must try that next time I can find a suitable locationmyglaren wrote:Which should be indicated at startup. Also a speed in excess of 6mph should override that.Another possibility is the center console "low" switch permanently made, again if max low is set the pump will not run.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
cachaciero
- x 9
Tried it today speed does override the button being held down so scratch that idea.cachaciero wrote:Yes I think you are probably right re the indication not so sure that speed would overide the "lower" switch if permanently selected, must try that next time I can find a suitable locationmyglaren wrote:Which should be indicated at startup. Also a speed in excess of 6mph should override that.Another possibility is the center console "low" switch permanently made, again if max low is set the pump will not run.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 5672
Yep, done that on mine too.cachaciero wrote:Tried it today speed does override the button being held down so scratch that idea.cachaciero wrote:Yes I think you are probably right re the indication not so sure that speed would overide the "lower" switch if permanently selected, must try that next time I can find a suitable locationmyglaren wrote: Which should be indicated at startup. Also a speed in excess of 6mph should override that.
cachaciero
cachaciero
Question is will it do it if there is a fault?
cachaciero
- x 9
Ah...! thats woken up something. If you make any selection on the buttons if the ECU is working it will advise you of the height change. Now if you select raise and and it cannot achieve the correct height it will flag "Suspension Failure".
If doing a raise or lower you get no messages it would suggest that the ECU is dead or not talking for some reason.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
carpy
Managed to check the big fuse in a small break in the weather this evening and current passes through it so it seems alright, checked across the fuse box where this fuse goes and with the engine running was getting permanent 12 volts, is this right. The car is completely slammed to the floor now. Any thoughts on what I should try next.
cachaciero
- x 9
Carpy
With respect there have been over the last four or five posts several things for you to check. Go sit in the car select high on the button see what indications you get then come back and tell us what you see.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
