Replacing the stereo - O.E. or aftermarket?
Father Ted
This one has probably been done to death, but I can't find any posts on it in here so I'll ask again...
I need to get a replacement stereo for my car (2001 Xsara). Is there anyway I can get a non O.E. stereo which can be operated via the steering wheel controls?
Alternatively, how much am I looking at to get a replacement unit coded to the car?
Finally, can new units be bought to fit the car and if so where can I get them? I know the sound quality would be better from an aftermarket item, but I've really go used to the steering wheel controls.
Toby_HDi
- x 3
It is possible.
Most units have a 3.5mm jack on the back for wheel controls. A brand specific patch lead is plugged into this and the other end goes to a control module that is small enough to sit behind the radio. The control module is connected to the main loom through a car specific adapter harness.
Sounds a lot, but it isn't really. Look to pay about £20 for both the patch lead and harness. Don't buy them from Halfords or ICE specialists, they can be found online MUCH cheaper.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
den169
lancia58
- x 8
Hi
Try this
http://www.dynamicsounds.co.uk/steering ... 7_185.html
I bought one for my Xantia it is plug and play, just make sure that Stereo Patch Lead is compatible with your stereo head unit.
Regards
Zohar
Try this
Regards
Zohar
Father Ted
lancia58
- x 8
The adapter is connected to the steering wheel control keys and to the stereo head unit. The patch lead is the cable that connects the adaptor to the stereo head unit. The patch lead has a jack that plugs onto the head unit string remote control, it should be compatible with the socket of the head unit. You should make sure that the had unit can be controlled via a steering wheel controls. Most Clarion head units have this option. In the following link
http://www.clarion.com/gb/en/products/2 ... 95480.html
look for “OEM Remote control”. Other manufacturers like JVC and Sony have this option on some of their products
Regards
Zohar
Regards
Zohar
Father Ted
Thanks for that pointer Zohar. i didn't realise I needed to look out for that.
Therefore, what about this head unit:
http://www.caraudiocentre.co.uk/product ... -26566.htm
As an aside how much does it cost to get a head unit coded for my car if I decided to opt for a a replacement secondhand OEM part?
Thanks.
Thanks.
When I got mine for the Xantia off Ebay the seller had the code for it, it was just a matter of fitting it and entering the code supplied, everything else then worked ok.
If you're buying a used one ask for the code to come with it, if you get one without the code it will cost you anything from a tenner up to get it recoded by a radio supplier. G.
Father Ted
Father Ted
Hi thanks for the help guys - I've ordered the harness and a new stereo.
Would any on here be abel to tell me or point me to instructions as to how to remove and replace the stereo? I know I need to remove the fascia - but how is this done without breaking it or snapping lugs on the fascia itself?
Many thanks,
Many thanks,
- x 1504
- x 1504
Aha! Some info here then when I was considering doing it on my Sister's car:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=27639
Father Ted
OKay got the radio semi installed, but having difficulty locating where the steering wheel connection block should go.
I've been told by the supplier that it goes under the steering wheel column. Does anyone know where exactly this connection block as I'm having difficulty locating it.
There is a ribbon connection located on the steergin wheel beside the wiper stalk - is that it?
Thanks.
Thanks.
