Xantia gearbox oil
froggy
(Donor 2026)
x 4
Xantia gearbox oil
Unread post by froggy »
Hi, just about to change (this weekend) my Xantia gearbox oil. A friend has just said , it"s really difficult to refill after you have drained it. He says, there is no room to fill it . Is this correct? cheer Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Toby_HDi
x 3
Unread post by Toby_HDi »
He is correct.
Fill it through the reverse switch hole using a funnel. Much easier. Most bottles are marked on the side so you can still know how much you've put in.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
VertVega
x 13
Unread post by VertVega »
Not difficult and best/easiest from breather plug which is a
plastic plug on top of gear box (17 or 19 mm I don't remember exactly) with a plastic cap.
Edit: and here's a pic
If you have manual box (like mine) then the gear box oil amount is 1.8 l.
froggy
(Donor 2026)
x 4
Xantia gearbox oil
thanks very much for the info ,
cheers Terry
Terry
VertVega
x 13
froggy, today I was busy with the battery and also had the opportunity to check the breather plug size :)
It is a 17 mm plastic plug.
PS: I learned breather plug tip from FCF 8-)
froggy
(Donor 2026)
x 4
Xantia gearbox oil
Cheers, thanks for all the help.
Terry
