1.9 TD
mongoose100
1.9 TD
Unread post by mongoose100 »
Hi all,
My grandfather is currently driving around with 100% WVO, that is until last night when she decided to stop on side of motorway! :shock:
Went to look at it today, thinking it might have a blocked fuel filter - was greeted with the primer bulb completely sucked in. My thoughts are that there is a blockage between that and the tank, haven't looked further into it because of the lovely stormy weather that we're currently having :evil:
Does this sound like the strainer in the tank being blocked?
Also, would I do more harm than good if I was to blow compressed air down the fuel lines from the bulb to the tank???
Thanks in advance!
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
x 8458
Regan,
You may find the tankl strainer is blocked up totally. It's quite accessible after removing the big rubber bung under the back sat and undoing the ring that holdids in the pickup assembly and gauge sender in the tank.
You may also find the return line back to the tank is choked too.
Often when running veggie 'things' grow on the strainer. John (jgra1) has a lovely picture of a whole new life-form growing on his.
It may just be the filter plugged but it's al ways worth a check of the tank strainer...
mongoose100
Hi ya Jim, Just been given bad news! The thing has had the fuel filter out for the last 500ks! Dont know how or why but Grandpa just found the thing in the boot! :evil: :evil: :evil:
Is this when I pray that the stainer is blocked, or does it suddenly sound far more sinister!?!?!?
Regan.
2001 Citroën C5 V6
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The strainer being blocked up looks to be the obvious cause, I'd pull the assembly out of the tank and investigate/remove the sludge (it's not a difficult/long task) rather than blow it back into the tank as all you're doing there is delaying the inevitable for when it happens again.
This is what I found on one a few years ago.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
