radius arm bearings
froggy
- (Donor 2026)
- x 4
radius arm bearings
Hi, someone told me today, that it would be better in the long run if I change the whole radius arm, not just the bearing. because its a pig of a job! Iam wondering about the cost of theses arms !! surely the bearings are cheaper ? any ideas ? cheers Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
rory_perrett
No too bad a job, changing the bearings in each arm adds about 1/2 hour a side to the job. If you have a spare set of arms I guess it takes the pressure off a bit to do the bearings first and then change the arms over. Cost wise arms + bearing are going to cost more than just the bearings.
Access to a wilder makes getting the old bearing race out of the arms so much easier.
froggy
- (Donor 2026)
- x 4
radius arm bearings
Sorry, but whats a "wilder" ?
Terry
Xantidote
- x 4
- x 94
- x 1240
- x 94
froggy
- (Donor 2026)
- x 4
radius arm bearings
I have found a thread by "Alan- s ", its taken from an bx , can I use this for my Xantia .
Terry
- x 1240
