C5 changer
john alexander
C5 changer
Unread post by john alexander »
Hi Is there anyone on here with a Mk 11 C5 fitted with a cd changer under the seat. I need some advice HELP.
Clogzz
x 40
Unread post by Clogzz »
Have a Mk I C5 with Clarion CD changer under the seat, but never used it yet.
x 1938
Unread post by Paul-R »
I have a Mk I C5 with CD changer under the seat and I HAVE used it!
Philjw
Unread post by Philjw »
I have a 2005 face lift exclusive where this is standard.
What's your question?
Phil
05 C5 Estate 2.0 16v + 05 C4 Hatchback 2.0 16V
john alexander
Hi phil , I bought a changer from a mk1 C5 but it wont install on lexia to my car. I have the cable under the seat but dont know if the connector on the back of the radio has the right cables . Would it be possible to take a pic of the back of your radio so I can check it against mine. Regards john.
x 1052
Unread post by wheeler »
I would'nt have thought the mk 1 & 2 changers would be compatible with each other as the both use a different type of multiplex network.
The radios are completely different aswell, the mk1 has ISO style connectors & the mk2 radio has the quadlock type connector.
Philjw
Hi John,
If you do mean the radio which is in the dash then I don't have tools to get it out. Would a shot of the under seat unit be any use?
Phil
john alexander
Hi phil the radio is held in by screws behind the holes in the front , T6 torx screwdriver if I mind right. If you could let me know the numbers off the label on the changer that would be great Thanks
Philjw
Hi John,
No joy with getting the radio out. I tried the smallest torx driver I have in the holes and couldn't feel screws.
Hopefully this should link to an image of the label on my underseat unit
http://s1128.photobucket.com/albums/m49 ... IM1529.jpg
and this should be the plug
http://s1128.photobucket.com/albums/m49 ... IM1531.jpg
Regards
Phil
john alexander
Hi phil the torx is a T10 , I took the radio out of my sons 407 ,it has two arial cables ???? and a set of extra wires in the connector , but has no cable for a changer under the seat or in the back . talk about a bloody mystery.
john alexander
Hi my radio doesn't have the cable on the back but the cable under the seat and my sons 407 has the cable on the radio but not under the seat. Are the workers at PSA just allowed to build the cars anyway they want.
KennyW
x 165
Unread post by KennyW »
John,
Phone Ray Smiths in Edinburgh and they have been very helpful to me in the past, hopefully they will adviseyou accordingly.
Kenny
C3 1.4 petrol (SWMBO)
john alexander
UPDATE I've just pulled the dash to bits to find the cd cable with no luck, had a look at the cable under the seat only to trace it under the carpet to a connector where it ended . AAAAAAGGGGGHHHHHHH
