Xantia II Cruise control problem
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
The cruise control in my Xantia II 2 stopped working. It was when I was driving on the freeway. At the beginning when I activated it, it worked for couple of seconds and stopped. I checked the vacuum unit that controls the gas throttle in looks OK . The switch on the brake pedal is OK and the relay that supplies power to the cruise control ECU is clicking when I push the handle that activates the cruise control. It feels like the cruise control unit tries to control the speed and there is a leakage in the tubing but that’s a feeling and haven’t validate it yet. Does anyone know where is the cruise control ECU ( the electronics that controls the speed once the cruise control is activated ) ? Any clues on how to track down the problem
Zohar
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
CitroJim had similar problems with cruise on his 'old V6' take a look through his blog and you get more details but from what I recall he found a split in the bellows which he repaired using a bicycle puncture repair kit. From your description of the fault I think its pretty much the same symptoms Jim was having. I'm not entirely sure on this but I think the ECU is under one of the front seats.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1484
Unread post by xantia_v6 »
Double-check for a split hose at the spigot on the pump
x 8457
This is a guide to fault-finding on the Cruise Control.
It covers almost everything so should elad you to the fault...
As said, it's 99% likely a split pipe.
lancia58
(Donor 2022)
x 8
I found that the bellows is punctured. I replaced it with one I found in wrecked car and now the cruise control works.
Zohar
x 8457
Zohar, you could have repaired the bellows with a bicycle puncture repair patch. I did this on my Old V6 a year ago now and it's still good.
Check the bellows is not fouling on the wiring loom nearby. That's the normal reason they get punctured. You need to ensure the offending loom is well out of the way.
lancia58
(Donor 2022)
x 8
I got the bellows for free from the garage I work with. The punctured one was in a bad condition and it was a matter of a short while till it will puncture gain. I’ll take care that the bellows is not fouling on the wiring loom nearby.
Zohar
