My Xantia started leaking coolant off the rear of the front subframe even when not running and I thought that I felt water around that plastic connector at the bottom back of the block. It was like a dripping tap(off the subframe) and so I ordered the new connector and refilled/bled the system as I had to make a short trip in the car. Blow me if it isn't leak tight now - as confirmed by several more trips including a couple of motorway blasts !
I'm guessing that he previous owner may have used something like radweld or similar to cure a leak and maybe that is the explanation but does anyone have any thoughts on this. In my day job I've found that leaks usually return when you are least able to deal with them!
The only further info I can give is that the car has never had a water pump in its 122K and there is a little rust haze on the timing belt cover.
The Leak that never was?
Be-Exer
Paul
93 Bx 19 TXD Estate
00 Xantia HDi110 Estate
93 Bx 19 TXD Estate
wotwot
- (Donor 2021)
- x 4
Is this a joke are you serious 122.000miles on one pump, possible but hard to believe it has'nt been changed during the belt change.
I 'm thinking it must have had the timing belt changed has it!!.
Whilst doing the waterpump about £15 You may as well do the timing belt as well.
Good luck with the job bit of a pain in the a**e to do.
fred1
Be-Exer
red_dwarfers
- x 58
