Hi chaps
I noticed yesterday when driving that my Xant seems well down on power. It would rev freely in second gear but seemed to struggle in a higher gear. Was OK cruising along the Dual Carriageway at 3k revs but when inclines were encountered the power dropped off noticeably, changing down didn't do much. I know the Xant isn't exactly a rocketship but this was noticeably worse than usual. I changed the fuel filter this morning as it is a simple task but it hasn't helped. My wife has taken the car until tomorrow so I won't be able to do anything else this weekend but I just thought I would see if anyone had any ideas.
Cheers
Lack of Power
Xaccers
- x 188
Air ingress in the fuel lines and leak off pipes perhaps.
May even be a split in the boost pipe to the ufo on the top of the fuel pump.
How old is the air filter?
DIY sphere tool
DIY sphere tool
Penguin
Xaccers
- x 188
Yes, a clogged air filter can have an impact.
DIY sphere tool
DIY sphere tool
mendedit
I have known a car to be stopped completely by a dirty air filter,
and it doesn't always look clogged,
Removing it and trying that hill again is the best way to test.
I have been known to wash a paper filter before and dry well, it works if strapped 4 cash! (short term)
The world is full of them and a lot are in
rory_perrett
miked
- x 6
- x 1488
It will be either a split in the small hose that runs to the boost compensator on the pump, or one of the large boost pipes has come adrift. You usually notice the latter though, as it normally happens under boost load, and is accompanied by a loud pop, immediate loss of power, and then a throaty noise
scared the life out of me when it happened about 10 miles after a cambelt change....
Old-Guy
- x 24
I agree with Richard and Xac that from the symptoms you describe, a split in the boost sense pipe (from big turbo pipe to 'space-ship' (compensator) on injector pipe is the most likely. If a turbo pipe has come off you'd notice the extra noise. Do check the underside of the pipe. The tell-tale is a misterious slight oil leak around the top of the engine - caused by some of the oily crankcase vent gases escaping from the split.
Otherwise air or fuel filters - don't forget there's a fuel filter in the tank!
mendedit
Penguin
Rory, I have changed the fuel filter already.
Mendedit, I think the brakes are coming off OK, it seems to roll downhill OK.
Everyone else, I'll change the air filter when the wife gets the car to me this afternoon. I won;t have time to check the hoses today but will have a look after work tomorrow. Is it obvious which hoses to look at? Not really sure where the turbo is. Somewhere near the back??
Cheers all.
Cheers all.
95 Xantia 1.9td SX
- x 1240
Penguin
