C5 CD CHANGER
john alexander
C5 CD CHANGER
Hi has anyone tried to fit a cd changer in a C5 ? Mine is an 06 plate with the wiring and cage under the drivers seat . There seems to be a few different model versions of the CLARION changer will any fit . I know it will need to be activated with a lexia . All help gratefully accepted
martinwiseman2000
Re: C5 CD CHANGER
I've not tried fitting a CD changer, so I can't help with that.
However, before going too far do check that you have ALL the wiring under the seat. My C5 (57 reg) has the wiring from the cage under the seat down to the floor, but nothing between there and the back of the radio. It looks as if the under seat wiring is a standard part of the seat assembly but the cheapskates at Citroen only fit the rest of the loom if you buy the CD changer.
Martin.
Martin.
