Battery terminal Powder
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all,
Ive a customer car which keeps dooing this:
Ive greased the terminal now to stop it but shall see end of this week if it has stopped it...
My Q is, what causes the POSITIVE to powder up like this??
Paul
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
maybe an electralight leak at the base of the pole ( a crack ???) Paul,
or there is a bad conection on the terminal, i see its got one of them oribble aftermeercat terminals fitted, with the secureing screws (NOT ) suposadly holding the core of the cable,
regards malcolm
x 1240
Unread post by Peter.N. »
I would agree Paul there is probably a crack in the battery or the acid is leaking up the terminal post, a good coat of grease should cure it.
x 8462
Not had this happen for years now but the old method was to clean off the corrosion by pouring boiling water over the terminal and then coating liberally in Vaseline as Peter says.... Vaseline in preference to anything else...
If it does not cure it and the batter is still good, clean it up really well again and pour a bit of hot pitch around it. Pitch was what was always used in the olden days to seal batteries...
x 1240
Don't they still use it? :)
x 8462
Peter.N. wrote:Don't they still use it? :)
Like everything these days, they seem to be all plastic nowadays Peter :twisted:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Women, too. :roll:
HDI
x 7
Unread post by HDI »
That is almost certainly a slight leak from around the base of the terminal.
I use Wynns terminal battery grease spray which is excellent at preventing the problem and also turns yellow in the presence of electrolyte thus confirming it.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 2938
disconnect it and wash it off with boiling water before you grease it or it will just come back quickly, don't use car grease use Vaseline or Lanolin. G.
addo
x 95
Very informative; I have the same problem on a cheapish battery so it's good to know the cause and solutions.
