xantia mk2 front bumper removal
imperial21
Unread post by imperial21 »
I have finally got my replacement bumper, which was removed by methords i would nt do to to get mine off, the big problem is getting at the midle 13mm bolts. how do you get at them ? as on a mk1 xantia you can pull the fog lights out, a mk2 xantia you cant !!!!! :evil:
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
x 8457
You need to fold back the mudshields under the front wings to get at the bolts.
MK1s, being far superior, had removable bungs in the mudshields to get at these bolts.
There's no need to fully remove the midshields, just remove sufficient bolts to allow it to come away from the leading edge of the wing to give sufficient access.
The bolts on a MK2 are 10mm and not 13mm as on the MK1.
Then it's just the three 10mm bolts under the bumper skirt across the front crossmember. Go easy as these can be tight and shear...
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Fog lights?? To get at Bolts?? :?: :?: :?
Ive never had to remove foglights to get at any bolts on S1 or S2 Xantias...
They come off in situ with the bumper...
Paul
A very sad...
1994 XM 2.1 d auto
imperial21
I only quoted the haynes manual lies ! :oops:
The bolts look very hard to acesess on the drivers side due to the washer bottle ! How long shold it take to do ?
citroenxm
Fallen Hero
x 70
Not at all
They are ABOVE the washer bottle, theres no need to bother with the washer bottle!!
Paul
A very sad...
1994 XM 2.1 d auto
x 8457
imperial21 wrote: The bolts look very hard to acesess on the drivers side due to the washer bottle !
No, actually once the mudshield is peeled back it's easy to get at with a 10mm ratchet spanner. It sits well above the washer bottle and in the clear.
How long depends on how well corroded in place it is. Give it a good dousing in Plus Gas before starting...
Estately
x 23
Xantia mk2 front bumper removal
Unread post by Estately »
Dont forget to unplug the spot light wiring (passenger side sort of behind the spot light) before you try and walk off with the bumper assembly.
Also there is a vertical torque screw (T15?) on the very tip of the bumper each side, screwed into a plastic gromet in the wing. Not sure if this is the same as the MK1
If it can happen it will.
x 8457
Re: Xantia mk2 front bumper removal
Estately wrote: Also there is a vertical torque screw (T15?) on the very tip of the bumper each side, screwed into a plastic gromet in the wing. Not sure if this is the same as the MK1
Good thinking :D I always (nearly) forget those...
And if you have headlamp washers, disconnect the pipe at the quick release connector just above the washer bottle...
