206 rear wheel bearing
glynn
Hi guys. Just after some info of how easy it is to change rear wheel bearing on 206sw and a guide of how to go about it. Been rumbling now especially when cornering for a few weeks so want to get it sorted. Thanks
- x 8203
If it's a drum brake then it's not a bad job but you do need a press to extract the old bearings and insert the new ones.
Then bearings are entirely within the drum and after removing the hub nut the drum comes off complete with bearings.
Renew the hub nut.
If you do not have a press then usually a local, friendly garage will do the job for you fr a small fee..
Renew the hub nut.
spider
- x 77
As Jim has said not difficult but you will need a press. A genuine new drum comes with the bearing from what I remember, 306's usually did anyway. Cannot really swap just one though.
Good time to check those wheel cylinders too, watch the little tiny clip on the brake adjuster as 206's are prone to falling out if played with.
Andy.
- x 8203
Been caught with that one Andy, a very good point indeedspider wrote:watch the little tiny clip on the brake adjuster as 206's are prone to falling out if played with.
If it's wrong the self-adjusters don't... I've been there and had to strip it again to make it right...
