Hi
Does anyone know the size for a saxo mk1 1.1 hub nut ?
saxo hub nut
imperial21
saxo hub nut
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
- x 94
i think its either 32 or 34mm, and its peened into indents on the drive shaft stub,
they do recomend you fit new every time they are removed,
i find quite often you can switch left and right from one side to the other the first time off,
and if your a real skin flint you can file the mateing surface down a touch, as this allows you to wind it a little, so you have unused metal to peen over,
regards malcolm
regards malcolm
spider
- x 77
Chris570
- x 36
imperial21
- x 94
