Unblocking a HDi exhaust NOW WITH Video!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all..
Ive a HDi 110bhp Xantia in, Ive found the non functioning turbo cause, so know what I need, but the next challenge is a blocked exhaust..
Well, its not completely blocked as the engine does run with it attached but theres minimal comming out the exhaust!
What is gonna be the easyest way to clear it out?? I damm good HARD blast with full turbo boost down the road or Im I going to have to remove it ??
With the engine idleing if I cover the tail pipe and let the exhaust pressure build up and remove my hand I get an almightly black cloud... this doesn't happen on my every dayer... so Im looking for sugestions for "Emptying" it
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Removing it is obviously the correct way but to save time you could try whacking it in strategic places with a hammer to dislodge the soot, especially if someone is blipping the accelerator at the same time.
I'd be careful about using the Italian tune-up method if its as bad as mentioned, I'd be concerned for the turbo both from a heat build-up point of view and the risk of back pressure as suffered by C5 2.2's.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Stempy
Unread post by Stempy »
In the old days of two stroke motorbikes we used to take the pipes off and set them alight :D
Lexia ponce
Deanxm
x 87
Unread post by Deanxm »
i would say this is whats killed the turbo, pull the cat of and beat the monolith out....................i mean take the old cat off and clean it out the best you can or buy a replacement Paul.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
dieselnutjob
Unread post by dieselnutjob »
straight bits of pipe are £10 or so from Partco
cut the cat out and replace with straight pipe
citroenxm
Fallen Hero
x 70
Cheers guys..
From an interesting point tonight, I found some working Vac Solinoids and put them on the car and started it up ...
And rev it wouldn't do... the exhaust BELLOWED black and smelly like "Cooked" Fumes out the exhaust, Ive got a video, but my laptop is dying a slow death and will not talk to any USB device... so I cannot upload it...
So I guess its pipe off and replce, OR cu the cat out and fit a striaght pipe!
Thanks for confirming.. Getting somewhere at last with this late one!
Paul
A very sad...
1994 XM 2.1 d auto
steelcityuk
Unread post by steelcityuk »
My favoured method is to cut the exhaust so the cat can be smashed out. Watch out for turbo spikes and over boost errors though, I've never had a problem but it has been reported especially after a remap.
Steve.
not applicable
citroenxm
Fallen Hero
x 70
Hi all..
I took a vid of the Hdi exhaust the other day:
Looks like this:
Paul
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
So thats full throttle, the restriction is sooooo bad you can hear the engine slow!! And yes she isn't reving freely, and Im just holding the throttle full!
Shes fine with the exhaust undone at the manifold!
Paul
A very sad...
1994 XM 2.1 d auto
Deanxm
x 87
Just being choked to death by the cat blockage, unless the silencers are rotten out and are filled with insulation thats dropped in and blocked the exhaust.
Amazes me how it managed to get so bad, no wonder the turbo was dead, must of cooked it alive.
D
XM Prestige PRV6 92
citroenxm
Fallen Hero
x 70
Right, confirms confirms... yes there was a burnt smell.. Think Ill drop the whole lot off manifold to back box...
Paul
A very sad...
1994 XM 2.1 d auto
miked
x 6
Unread post by miked »
So do you think the cat is blocked?
If so. I 'unblocked' one on my old petrol xsara vtr with a metal pole and a lump hammer. It didn't pass the MOT afterwards and in hindsight I should have weighed in the cat and put the money towatds a replacement.
But a diesel doesn't need a cat, so depending on condition, either replace it with a new bit of pipe or smash the insides out of it.
Deanxm
x 87
looks like a nice car Paul, like the colour too.
D
XM Prestige PRV6 92
citroenxm
Fallen Hero
x 70
She IS very nice, its maritious blue, SX HDi 110, with just 117k, new clutch 2k ago, and anew cam belt and water pump 3 k ago, receipts to proove too..
X plate 2000 model too...
Miked, it has to be a blocked cat, with the pipe dropped off I was getting full revs, and with lexia attached with live parameters, 1500 mb turbo boost pressure! Only after I tightend the exhaust back up she - well tried to die...
Paul
A very sad...
1994 XM 2.1 d auto
Deanxm
x 87
yours?
XM Prestige PRV6 92
