My Xantia Washer fluid reservoir Seems to be clogged, i takes ages to pour half a liter there, is there a way to fix it?
windshield washer reservoir!
- x 8458
You may find the vent pipe on the top of the reservoir is blocked. It's just a piece of clear plastic hose that allows air to bleed in as you filll. It can easily become trapped or covered in mud.
Take off the mudshield on the drivers side and you should be able to see it and deal with it.
Ref
OK gonna try that, thanks Jim.CitroJim wrote:You may find the vent pipe on the top of the reservoir is blocked. It's just a piece of clear plastic hose that allows air to bleed in as you filll. It can easily become trapped or covered in mud.
