Low Oil Warning
Chlorate
Low Oil Warning
Unread post by Chlorate »
Getting annoyed with my low oil warning light, it keeps flashing at me even though there's plenty of oil in there. A few cycles of the ignition tends to stop it.
I've heard these are a common fault on the XUD engine.
So how do I shut it up?
New sensor I'm guessing, but is it easy to get to?
Thanks,
-Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
Xaccers
x 188
Unread post by Xaccers »
Are you using semi/synthetic oil?
DIY sphere tool
Chlorate
Yes, semi synthetic 10w40.
previously:
Xaccers
x 188
The sensor triggers on semi/synth, not a lot you can do.
Doubt even a new one would make a difference as I'm sure my 3 yr old Xantia used to do it.
DIY sphere tool
HDI
x 7
Unread post by HDI »
How would oil type make a difference to the way the sensor reads ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Chlorate
Aah, nevermind then, thanks Xac.
I'd guess it'd have something to do with the oils having different density. But without knowing how the sensor works it's probably not a good guess :D
previously:
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Hi Alex, my TD does it as soon as level gets about half way between low and high on the stick.. i only use cheepo oil in her..
I ignore it for the most part, it should switch off after 20 seconds or so..
I do occasionally check the oil level to make sure the light has not given up crying wolf :twisted:
john
Chlorate
That's about where mine's sitting at the moment actually. Got a fresh bottle in the garage, will be doing a good service before I have to ship some people up to Silverstone in July.
I do get paranoid sometimes and pop the bonnet after the nth time I've ignored it that week.
Oddly enough it didn't warn me when my oil level was actually low earlier this year :?
previously:
Dommo
x 20
Unread post by Dommo »
Mine only does it if it's parked so the nose is down and leaning towards the drivers side, so the passenger side door is higher than the drivers side. It does it without fail if I park in a certain place on my drive. If I park on the flat or nose up it never cries wolf, and thats with fully synthetic oil. I cant see the oil type making a difference
Do you park somewhere that means the car leans like that?
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Dommo wrote:Mine only does it if it's parked so the nose is down and leaning towards the drivers side, so the passenger side door is higher than the drivers side. If I park on the flat or nose up it never cries wolf, and thats with fully synthetic oil. I cant see the oil type making a difference
My Xantia's are the same.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Xantidote
x 4
Unread post by Xantidote »
Oddly enough, my TD started with the flashing light a couple of weeks ago, which has never happened before. Have used same Millers semi-synthetic oil for last 10 yrs.
Oil level only just below max, and will top up to max to see if it cures it - more annoying than anything, and my sharp eyed young daughter has even seen it from the back seat - "what's the flashing light for, Daddy"
Havn't had problem long enough to establish the car leaning characteristics :lol:
Martin
1995 Xantia TDLX (deceased :( )
Old-Guy
x 33
Unread post by Old-Guy »
Dommo wrote:Mine only does it if it's parked so the nose is down and leaning towards the drivers side, so the passenger side door is higher than the drivers side. It does it without fail if I park in a certain place on my drive. If I park on the flat or nose up it never cries wolf, and thats with fully synthetic oil. I cant see the oil type making a difference
Mine has always done exactly the same. Originally on mineral oil, on semi-synthetic for the last 2 years - makes no difference, it's the slope what does it. I always try to park nose-up to eliminate the risk of rain water creeping under the tailgate seal.
