Tyre wear ?
froggy
(Donor 2026)
x 4
Tyre wear ?
Unread post by froggy »
Hi, the tyres on the rear of my Xantia are wearing on the inside edges . They have never been on the front of the car . What would cause the wear on the inside edge ? Cheers Terry
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Xantidote
x 4
Unread post by Xantidote »
First thoughts would be wear of the rear radius arm bearings. Any clicking or creaking from the rear suspension?
If you stand a few yards behind the car, and look at the rear wheels, do they look /--\ ie. leaning inwards at the top. I've never seen this myself, but it's a question that crops up regularly in postings as an indication of failing bearings.
You should find a wealth of information on the Forum - try a few searches :)
Martin
1995 Xantia TDLX (deceased :( )
x 94
Unread post by citronut »
im with Martin on this one, its easyer to see the / \ wth the car on high,
regards malcolm
rory_perrett
Unread post by rory_perrett »
I'd go for rear arm bearings as well. On my BX it was very obvious that they were on the way out, on my Xantias no so. The last time I changed a set there was no sign of the / \ effect and it was only a tyre wearing in a funny way like it does when you have a faulty shock absorber that alerted me to a problem. When I did take them off them off they were clearly shot.
