Xantia front end drops...
DHallworth
- x 167
Since I changed the spheres and the electrovalve on our Xantia on Saturday occasionally when opening the front door the front of the car drops several inches.
It did it last night and the front bumper landed on the kerb. It didn't damage the bumper luckily but it's only a matter of time before it will.
I've got a feeling that the front electrovalve has been faulty for a while so I think it's changing that that's causing it to drop.
I was under the impression that the centre sphere was cut out of the system when the door was open as it goes into hard mode, so can't understand why the front is dropping.
Also, with all new spheres on the car, the oldest of which was date stamped April 2011 the ride on the car still isn't as smooth as I'd hoped it would be. Might just be me imagining things though.
Any advice would be appreciated.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
addo
- Sara Watson's Stalker
- x 95
Xaccers
- x 188
When did you last change lhm/hydroflush?
DIY sphere tool
DIY sphere tool
DHallworth
- x 167
Xaccers
- x 188
Sounds like an internal leak in the electrovalve, so gunk could be preventing it closing properly or I belive there have been posts saying the spring inside can get weak.
What's your tick rate on idle?
DIY sphere tool
DIY sphere tool
- x 8391
Very likely. An interlayy leaky electrovalve makes a noise like a flushing loo as the engine stops and all the LHM rushes up the leagake gretrn pipe.Xac wrote:Sounds like an internal leak in the electrovalve
A more determined test is to disconnect the leagake return pipe and direct the leakage into a large jar.
The leakage return should only flow when thew valve is switching and as it switches so it will spurt. In hard or soft leakage should be minimal.
With the door open the system will be in soft modse so yes, the centre sphere is in operation.
Soft is in force when:
The engine is idling and car stopped;
The engine is off and any door is open but will time-out to hard after 30 minutes;
The engine is of and all doors closed. Soft for 30s after last door closed. Then hard;
If in hard after a timeout the system will switch soft as soon as any door is opened.
Hard is in force when:
Engine is off and all doors have been closed for over 30s;
Rapid accelleration;
Hard braking;
Heavy cornering.
citroenxm
- Fallen Hero
- x 70
Re: Xantia front end drops...
Its an Hydractive car - they arent always as smooth as SX standard syspension..DHallworth wrote: Also, with all new spheres on the car, the oldest of which was date stamped April 2011 the ride on the car still isn't as smooth as I'd hoped it would be. Might just be me imagining things though.
David.
In seriousness though, has the car got a ECrofting box fitted?? Mine has and it works a damm treat.. theres an obvious difference between sort and hard. May be worth checking that for smoothness if the Diodes are dud...
The Crofting kit is in with the Cars ECU box on the left front...
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DHallworth
- x 167
Chris570
- x 36
I'd be very surprised if that causes the front to drop, my HDi went through a period of doing this, used to really annoy me. I would have thought the sudden drop proves the elctrovalves are opening.
the front sinks down about an inch if left for over 6 hours-ish, do you get that on yours?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
citroenxm
- Fallen Hero
- x 70
Chris570
- x 36
- x 8391
David,
I'd be almost certain it's the front electrovalve after seeing Xac's Juliet exhibit similar behavior a couple of times this evening.
She has an intermittently 'sticky' front electrovalve and sometimes he sticks half way between hard and soft effectively;y leaving the suspension in hard mode.
You can prove this is the case by bouncing the front end and then going full high and back down to normal again. If she's hard after that then there's the problem.
Xaccers
- x 188
Juliet also has a crofting box fitted, so could that be playing up Jim?
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
Chris,Chris570 wrote:you sir make an excellent point. (and to think i just gave someone else a rollocking at work for not reading all the required info)
*goes and sits in the corner*
I howled at this... its not a problem LOL... but to think you rollocked someone for dooing the same, is what made me laugh...
LOL
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8391
I did a quick check and I don't think so. A check with an AVO suggested it was working. To confirm properly I'll need to pop my oscilloscope on to itXac wrote:Juliet also has a crofting box fitted, so could that be playing up Jim?
I must confess I did initially point a finger of suspicion at the Crofting box.
David, to check, do you have access to a 'scope?
This is what you should see across the electrovalve at the ECU end if the Crofting box is doing it's job...
That picture was taken a couple of years ago on my V6...
