The 5 second tick.....
cheesey
Unread post by cheesey »
hi all,
I have a 94 1.9 td xantia like to "tick" every five seconds. In an effort to bring the ticking back into line I've changed The accumalator sphere, flushed and cleaned, new regulator and a new FDV because the steering didn't like to be powered.
No use.
In an effort to isolate the internal leak I lowered her to the ground and still she ticked on.
Am I right to think that this is the brake valve?
any other tests I could do?
She rises fast and sinks pretty well fast to.
might have to put the wife on the streets to pay for it all.....
thanx in advance.
blueboy2001
Unread post by blueboy2001 »
Mine has the save problem and I bought a brake valve and had murder fitting it and it made not a jot of difference. The brake valves are of an inherantly simple design and unless the LHM was full of grit or metal and run for ages I can't see how it would wear significantly.
I've written it off as a bad job now, there's obviously something in the hydraulic system thats worn but mine drives ok. I find I can stop the ticking by turning the steering wheel a bit if I find it embarassing. The value of early Xantia's is so low its just not worth spending a fortune on the hydraulics when you can go out and pick another one up for under a grand that will have the revised hydraulic system without the FDV and a more reliable pump.
AndersDK
Unread post by AndersDK »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">... might have to put the wife on the streets to pay for it all..... <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
..don't [:)]
- she might find a new life w/o Citroens [;)]
As for the other lady in your life :
- try test the return flow from the brake (doseur) valve - that would tell you.
If no obvious disastrous flow - then the PR may well be suspected.
How are you sure the new acc sphere is good ?
cheesey
Anders, Oh god of this forum....
New and had tested, within 5 psi of Citroen specs.
whats a PR?
The wifes beginning to slap on the makeup.....
AndersDK
Pressure Regulator.
