Xantia steering rack gaiter
froggy
- (Donor 2026)
- x 4
Hi, I have just fitted a new gaiter to my steering rack. What a job ! After much effort, I squezzed on the gaiter but cannot get it to sit on steering end , I get one half on then the other slips off! so Iam unable to cable tie it . Anybody got any ideas, cheers Terry
the_weaver
I had a lot of trouble with the steering rack gaiter on my ZX, so I know it's an awkward job. I didn't have any trouble getting the large diameter end to stay on though. Are you using a genuine Citroen gaiter, or is it an after-market one? Could it be that the gaiter is slipping off because it's greasy? If so, clean the grease off with some meths, just on the bit where the rubber sits in the groove in the metal. Does the gaiter sit in a groove on the Xantia? On the ZX, you have two spring clips to hold the gaiter on. They look like a "figure 8" when they're closed. They're awkward to put on though. I managed to do it, but was considering using a tie-wrap. Have you tried moving the steering wheel to compress or expand the gaiter? I suppose you could try some Super Glue to hold one half on a bit better, whilst you struggle with the other bit. It will stick rubber to metal, if there's no grease present. You might tear the rubber though, so be careful.
One more idea - rather than putting one side on, then putting the other side on, try pulling the gaiter on in one operation. You can use three bits of wood to do this, maybe three ice lolly sticks or bits of clothes pegs. If you space the three sticks equally, around the circular metal piece, you should be able to slide the gaiter up the sticks, until it's in the groove. Or, you could use the sticks as levers, to expand the gaiter a bit. Be careful, as it's very easy to slip and make a hole in the gaiter.
Paul
Paul
red_dwarfers
- x 58
froggy
- (Donor 2026)
- x 4
Job now done, what a job ! probably a silly question, but is there a tool available to help you fit the gaaiter ? cheers Terry
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 8460
Re: Xantia steering rack gaiter
Terry, I know only too well what a rotten job this is...
There's a certain knack to it.....
They have been used on one occasion as a tool to fit a gaiter. Ask Xac!!!!!!
No, unless you count me and my girly fingersfroggy wrote:is there a tool available to help you fit the gaaiter ?
