help LHM under tank
modxl
help LHM under tank
Unread post by modxl »
hi guys m,y td has decided to cover the bottom of its self in lhm under lhm tank and around that area but cant seem to find a leak any ideas ment to be of to germany in a couple ov days
xantia td
soon full leather
rear spoiler
x 8458
More than likely the anti-sink valve has popped a seal. Does it sink now?
There are also a few low-pressure leakage return pipes under there that can perish and leak. One favourite is the 'F' junction where the two front strut returns join together and go to the reservoir.
Wet LHM should give the game away as soon as you lift the tank up.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I wonder even if the Low pressure return pipe has popped off...
Down under the car, gearbox end, theres a Push on 3mm return junction that pushes onto a return pipe, these can come off VERY easyilly, even when changing a handbrake cable..
I reckon this has popped off....
Paul
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
or even if the top of the tank is wet with citro blood it could just be over full,
so when the car settles all the way down it weaps out from under the rubber dust seat around the tank float/filter unit,
regards malcolm
modxl
cheers for replys guys found it,o ring was leaking on valve block under oil tank five minute fix,had one ove them weeks while under car gave it a once over and found exhaust rusted through,lucky got a spare car here as a breaker with 2 mth old exhaust so that went on cheers again/steve
xantia td
soon full leather
rear spoiler
