Does anybody know where the loom for the front seats ends up?
From the seats, it disappears under the carpet towards the front of the car.
I've just had a look at swapping my Activa seats for leather to find that the loom is not in place in the Activa, I only have the wiring for the electric height adjustment.
Front seat loom
Toby_HDi
- x 3
Front seat loom
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
Toby_HDi
- x 3
Have also just discovered I don't have the wiring for heated seats either.
Hopefully it all ends up at a connector where I can just unplug that part of the loom and replace it with the loom needed. I very much doubt it will be that simple though.
Toby
Previous:
Previous:
DickieG
- Monaco's youngest playboy
- x 33
Don't worry too much about not having the front seat loom, when I fitted electric seats to my VSX I also only had the basic section attached to the seats so I soldered on a connection to the main ignition feed just prior to the ignition switch and put a fused link in for safety.
As the seats are rarely adjusted there is little chance of overloading the wiring, especially as the heater fan won't be running prior to start up and you won't be starting whilst adjusting the seats!
The heated seat loom is another matter but before you bother with that does the drivers seat heater work?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Toby_HDi
- x 3
I was rather hoping a short bit of the loom could just be replaced. Saves messing with splicing and soldering. But yes, I could just do that. I could probably just tap into the existing wiring under the seat as the Activa seats have electric height adjustment.
I don't know if the heater elements work. If they don't they are easily enough repaired anyway. I had to repair one on the Coupé.
Toby
Previous:
Previous:
