Hello!
During one year the LHM was dropped from the rear plug of the anti-sink valve (250 ml was topped) and today it came: fountain of LHM after engine starting.
Some month ago I asked this forum about this valve and realized, that nobody has any experience-the valve is high-ability unit.
Tomorrow I want to try dismount it and replace the problematical O-ring (instead planned timing belt replacing[B)]).
My question is: did anybody get any information since some month?
Any hint will be appreciated.[:)][8D][:D]
Anti-sink valve-again
JohnD
- x 72
If LHM is dripping from the anti-sink sphere, it must be coming from the 9mm union which goes into the back of the sphere. When I removed the anti-sink from my Xantia there wasn't a rubber sealing ring on it. The sphere just screws into a bracket. The LHM enters through a union at the back of the bracket. If you intend to remove the sphere, undo the pipe union first, otherwise you'll twist the pipework.
mark_l
John,
Sorry, I wasn't specific enough: the problematic valve is one, which is located under LHM tank and has not it's own sphere.
See link: http://www.fam.aust.com/keller/cit1/pic7.gif
Mine is hydropneumatic (upper picture)-the LHM leak is from lowest plug sealed with O-Ring.
Dave Burns
- x 3
- x 1060
