Hi , Iam trying not to panic, I have just noticed the gaiters on my struts have slipped down ! Does this mean my strut tops are about to fail ?
cheers Terry.
Xantia strut gaiter
Xaccers
- x 188
No it means you have the fun job of pulling them back up into place
You might want to lube the struts before you do though.
Check the state of the strut top bases while you're under there though.
DIY sphere tool
DIY sphere tool
froggy
- (Donor 2026)
- x 4
Xantia strut gaiterSorry
Sorry to sound green , very green, but what do you mean by "lube" ? is that grease them .
cheers Terry
cheers Terry
- x 8422
You can grease the strut pistons (the shiny bits) with thin grease but often, just a wipe of LHM is good...
Before you pull your gaiters up, check that they're completely free to rotate against the strut leg else they'll just fall down again. An accumulation of dirt in the bottom gaiter groove where it sits on a ring on the strut can hinder its ability to rotate.
Best way is to give the top groove of the gaiter a small wipe with LHM, ensure the ring on the underside of the strut top is clean and then grasp the gaiter and sort of 'screw' it on to the strut top ring.
It can be a bit of a fun job... A dash of PERCYWHATSIT will see it done... Don't try to use anything but ands or fingers to assist the process as the use of tools may damage the gaiter...
- x 5674
- x 8422
No, you can use it for 30 days for free and then you have to activate it via the phone..myglaren wrote:and you have to pay £5 to use it now.
It's become a core component of Internet Exploder 9. You'll need all the PERCYWHATSIT available to be able to recover from the massive memory leak IE9 causes when it's been running for a few hours. The first you know of it is when Windows becomes as responsive as a drum of tar
- x 5674
But Windows comes out of the box like thatCitroJim wrote:No, you can use it for 30 days for free and then you have to activate it via the phone..myglaren wrote:and you have to pay £5 to use it now.
