it started off with problems starting and losing a bit of power on the parkways when accelerating but would then suddenly kick in again but then it quickly changed into it wouldnt start full stop,i got it to a local diagnostic garage and they read the codes and told me it was the fuel pump so i got it home and ordered one off an online scrappy to which they sent a bosch pump when i requested a delphi one. so i sent it back and ordered one from somewhere else which they fobbed me off by not sending it within a month,so i dememded my money back and after 6 weeks and a solicitors letter i finally got my money back off those which ment i had to get it from somewhere else,in the end i rang all the delphi service centers and got a recon one at a good price
i fitted the new pump (and changed the belts etc while i was at it) and i started the car up and it started pretty much first time(as a novice/amatuer machanic i was sooooo happy) so my wife drove the car 100 odd miles to her parents for a visit but when she came home she went to start the car and lo and behold same problem
i then did some more reaserch on here and saw about a leak of test so i made up a kit and tested the injectors and found 3 to be quite bad(1 very bad)so got to work on changing those,2 came out very easily and 1 was an absolute nightmare but i got there in the end,i took them to a local delphi center and got 3 exchange ones,got home and fitted them-i re used the old high pressure pipes because after all the expense i've had so far i dont wanna pay another £150
then this weekend my lexia 3 arrived so i set about programming them in which i managed to do quite easily-checked and doulble checked that the codes stayed in,i read somewhere on here that cylinder 1 is near the gear box and 4 at the timing belt end...is this correct?
so now i have a new pump and 3 new injecters fitted and all progrmmed in but it's still not good,it still doesnt start straight away-takes about 5-10 seconds of cranking when cold but starts ok in mid afternoon and theres still a lot of white smoke under revs
any idea what the problem is cos im all out of plans now and im due to sell the car to my sister as soon as its fixed so i dont wanna sell her a bag of bolts????????
thanks in advance
adam yates
