Managed to get someone to read my car. Quite a few errors.
I would be grateful if you could help. See it as a quiz.
The two main ones revolve around the airbag which has a permanent fault and the light has been lit since last summer.
The other I suspect is related to the main problem I am experiencing now and which is the subject of this thread. Namely the STOP warning and temp light and guage zooming up and down.
I will discuss these first and put some other faults beneath them in case you want to comment.
MAIN FAULT 1, the Coolant temperature
P0115 Temporary fault. Coolant temperature signal - short circuit + or open circuit.
P1519 Temporary Fault. Cooling function incorporated into ECU consistency between fan unit speed and setting.
ON INSTRUMENT PANEL
Remote Fault, Intermittent Fault- Coolant temp incorrect value recieved.
THE AIRBAG
P1801 Permanent Fault Drivers level Airbag igniter open circuit.
Could this be the wiring having been pulled under the drivers chair? If so where is it?
OTHER FAULTS:
P1521 Permanent Fault Clutch switch Signal - coherence with vehicle speed?
P0571 Brake Switch signal Communication fault. Battery 13.5v
P2211 AIRBAG Front Right Satellite not defined.
P2210 AIRBAG FRont LEft Satellite not defined
P1537 Accelerator Pedal Jammed (V84->) Strategy Active
I Also had a number of faults which had NO code.
Engine Speed incorrect value recieved.
Vehicle Speed incorrect value recieved.
Battery Voltage seemed to be 14.2v but this was just a reading on one of the code pages so not sure if this is a true reflection of battery. Couldn't carry out battery test as don't have voltage meter.
Code help
- x 1056
As far as the airbag fault is concerned have a read of this > http://www.frenchcarforum.co.uk/forum/v ... s+footwell
- x 5675
Cheap multimeters abound these days and even more advanced ones can be inexpensive.
Something like this one should be adequate.
When Paul read my codes it came up with the 'stuck throttle' thing but it patently wasn't stuck.
It has been suggested that the throttle pot may be experiencing dropouts due to wear on the tracks but I haven't observed any flat or dead spots.
boristhespie
- x 4
Xsarahdi
Yes that sounds exactly like the coolant temperature sensor as I had the same symptoms with a Xsara HDi 110 in Winter time so it was obvious that it wasn't overheating. The sensor was around £12 at the time (18 monts ago) and is fairly quick and simple to do. Once changed I never got any more coolant temp warnings.
2005 C3 1.6 HDi 110 VTR
2003 Xsara 2.0 HDi 110 SX
1999 306 1.9 TD Meridian
1996 ZX 1.9 D Elation
boristhespie
- x 4
- x 5675
boristhespie
- x 4
- x 5675
MikeT
- x 232
boristhespie
- x 4
KennyW
- x 165
Hi Boristhepie,
I think this is your part no 1338 C1 green temp sensor cost £15-02.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
boristhespie
- x 4
