LHM pump leaks
dieseldoggy
LHM pump leaks
Unread post by dieseldoggy »
Hi my pumps leaking but not from shaft as when put finger there its clean. looks like from blanking plugs big one on front etc as been leaking onto alternator.
Whats the normal way to go about it or whats ones that usually leak etc and what seals/o'rings it need? cheers
xantia 19td estate 96-7
red_dwarfers
x 58
Unread post by red_dwarfers »
I've had a similar thing on both mine.
If you unscrew the blanking plugs, you'll find two seals which have gone rather hard. You can get replacement seals from the main dealer. Think they're about a quid each mind, but they are LHM proof.
Kev
'19 C4 Cactus 130 Flair
x 94
Unread post by citronut »
only one seal per plug i belive, but there are two diferent siezed seals on any one pump, as there are two diferent sized plugs,
also just remove the plug/cap and be carefull not to disturbe the plundger inside/under the plug,
below is part No. and dimension's if your is a 6+2,
the first one being for the plug frontmost top of the pump,
4026 88
HYD OIL O-RING
DIAM 19-TO 2,4
- PRESS PUMP 6+2 + NON-SINKING
4026 87
HYD OIL O-RING
DIAM 16-TO 1,9
and price/part No. below
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000402687 HYD OIL O-RING 1.36 GBP 1.63 GBP 1.63 GBP
0000402688 HYD OIL O-RING 1.16 GBP 1.39 GBP 1.39 GBP
regards malcolm
red_dwarfers
x 58
Damn! I knew what I meant :P
Interesting one that Malc, I'm sure I've used the same sized seals for the blanking plugs on mine.
Kev
x 94
spoz anythings possible Kev :shock: :twisted: :wink:
regards malcolm
Xaccers
x 188
Unread post by Xaccers »
The torx ones take the other size, both hex ones take the same size.
The torx ones rarely leak.
DIY sphere tool
