Got an intermittent problem on my wifes laguna II estate were the tailgate won't open or the glass window section either , tried taking the button out and cleaning it up but no luck , the contacts do look quite corroded though , when the car is locked you can hear a high pitched beep from the nearside rear area where the alarm box is located then after a while it stops , any ideas , my moneys on the switch but could it be anything else ? Thanks ,
Mark
Laguna II tailgate won't open
R9UKE
- x 3
Normally I would suggest a failing boot catch (it gave up on my Mégane), but as the glass section doesn't respond either it sounds more like the car is either "forgetting" to unlock the boot, or there is a loose connection or worn wire somewhere. I would check where the wires go from the boot into the car for any damage.
French is best.
bxzx16v
- x 34
bxzx16v
- x 34
Re: Laguna II tailgate won't open
This very same fault is back , before Christmas I fitted a new tailgate release button to the tailgate as the old one was faulty/corroded , this helped for a day or two now the tailgate refuses to unlock and the high pitch beeping is back, also the interior light in the boot will not go out so I have had to remove that . It seems there's no power going to the tailgate release button or the glass release button , does anyone have any ideas as this is starting to p**s me off , thanks
Mark
Mark
R9UKE
- x 3
Mark Is the display on your dash showing the boot as open all the time? It sounds like the car thinks the boot is open. The high pitch noise also makes me think this, my Mégane does it if you lock it with the bonnet open.
French is best.
bxzx16v
- x 34
Yes Luke the dash display is indicating that the tailgate is open even though it's not , trying to keep the spending on it to a minimum as it may be going soon
Mark
Mark
bxzx16v
- x 34
Got to the bottom of the tailgate refusing to open , it was down to a dodgy boot catch which was very damp and the solenoid in the latch past it's best . Ordered one today from the dealer so this should cure it when fitted , I'll post progress as & when
Mark
Mark
