My own record for changing spheres
Diabolical
Unread post by Diabolical »
I eventually got round to changing front/rear Hydractive and 4 corners.
40 mins :shock: On Xantia Estate.
They all unscrewed by hand :shock:
Both rear corners had split, I don't rate GSF spheres myself.
I used non hydractive for corners what a difference, lovely soft ride, feels like completely different car.
Gone from fast positive handling to motorway cruiser.
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
Xaccers
x 188
Unread post by Xaccers »
Split spheres should be the easiest to remove as there'll be no pressure to hold them tight.
How long had they been on the car?
DIY sphere tool
x 8458
That's good going :D
Hydractive rear corners can rupture without you being aware, I've seen it several times now...
Non-Hydractive spheres do work well for comfort but you may find damping is a little below par if things are pushed or the car is very heavily loaded...
GSF Spheres are normally not too bad...
Diabolical
Xac wrote:Split spheres should be the easiest to remove as there'll be no pressure to hold them tight.
Been on 30 months, N/S rear ruptered for 12 months, rear kept sinking then rising again on startup.
citroencx.co.uk
x 8458
Diabolical wrote:rear kept sinking then rising again on startup.
Classic sympom of ruptured corners :D :D
Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
rear keeps sinking and rising again on startup?
that sounds worrying like mine.
Since I changed all spheres (with the exception of the rear anti-sink) everything seemed as hard as before.
Got around to changing the anti-sink at the weekend and as soon as I switch the car off, it starts going down. It rises again on startup. Strange behaviour or normal?
Diabolical
Rhothgar wrote:rear keeps sinking and rising again on startup?
I never changed anti-sink and rear is dropping again :? though only slightly, but I'm sure will slowly get worse.
citroencx.co.uk
