Hi all, I have two problems that I need you help with,
1st, The headlights wont go off on the car a C2 Vtr sensodrive. now my daughter said she was in the car and slipped and hit the indicator switch, she said the headlight came on then and wouldnt go out. I disconnected the battery but the lights came back on when re connected.
2nd, The drivers door outside handle has broken, it has pulled off on the outside.It isnt broken itself. I tried feeding the it back into the door and moved the white part inside the door to re locate the handle, but it still doesnt work.
Can anyone help???
Paul
C2 HELP
spider
- x 77
1 Is worth trying it on a Lexia, although as far as I'm aware the Com2000 does not need coding in, unless you have a steering angle sensor. It may just be time to have a new one unfortunately, they do sometimes just fail.
2 That sounds like the actuator itself or a plastic part thereof is broken, although not having seen it I'm not 100% sure.
Andy.
- x 1055
The Birdman
Has it Autolights?
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
wrinklet1
The Birdman
If your able you need to replace indicator stalk on com2000 unit or the whole unit .
