seat anchorage point is loose - xsara 1 coupe
eurotrotter
Unread post by eurotrotter »
alrite folks
hope yer all keeping well
just noticed that the anchorage point for the RAILS is loose.
its not the bolt, its actually the mounting point is loose
its on teh drivers side
wat could have caused this
btw the car is a 3 door, so i guess it would have been subject to more movement and abuse.
wat i also noticed is that the both front seats do not tilt fully back. i.e. i couldnt sleep in teh car when i went to nancy, france last week!
any help on this would be great,
thanks
x 94
Unread post by citronut »
maybe the tin worm is active,
or the welded???? nut/s have come away,
regards malcolm
Xantidote
x 4
Unread post by Xantidote »
"tin work" = tin worm? :)
Martin
1995 Xantia TDLX (deceased :( )
KevMayer
Unread post by KevMayer »
I had this on my first Xantia Activa.
The front left bolt fixing of the driver's seat had broken.
As seen in this close up of the floor pan:-
Cheers, Kev
x 5688
Xantidote wrote:"tin work" = tin worm? :)
Fixed :)
x 94
has someone been tin tin tin kering with me posts again :lol: :wink: , spoz thats you is is Sir Steve,
must be mixeee me tosey's :shock: , or do i meen fingery's :lol:
regards malcolm
x 5688
citronut wrote:has someone been tin tin tin kering with me posts again :lol: :wink: , spoz thats you is is Sir Steve,
must be miee me tosey's :shock: , or do i meen fingery's :lol:
regards malcolm
Better make it toeseys Malcolm, not many fingerses left :)
