Have just bought a low mileage ZX 1.9 (non turbo) and everything seems good except a judder when moving off. If I engage the clutch gently all is ok but if I need to make a quicker getaway it judders as the clutch bites.
Is this likely to be a worn clutch or could it be engine mounts?
Thanks.
ZX 1.9D Clutch Judder
spider
- x 77
Its likely the clutch itself although engine mounts are a point I would of mentioned.
Drive at about 30 mph in 3rd gear and try acc on and off listen carefully for noise. It will shunt if you are a bit vicious with it but excess should be noticed.
The other (easy) way is to see how much movement there is in the gearbox (under battery) mounting.
The rear one tends to wear but that's oil contamination, that will give a shunt on acc on / off usually not judder.
If changing clutch ensure you get all three parts (well two if its the push clutch)
Andy.
- x 1240
Very often giving the clutch a gentle burn off will cure it, try slipping it a bit as you pull away a few times. I have had this problem on several diesel clutches and I'm sure its caused by lack of slip when pulling away because of the excellent low down torque, I think the surface of the plate must get rough because a bit of slipping usually cures it.
- x 94
- x 8168
A D is likely to be a push clutch Malcolm
So much easier....
On these push clutches, mainly on 205Ds, the problem has been that the release bearing has worn a groove in the diaphragm spring tips and this causes judder as the release bearing rides over them at bite point.
The D push clutch is a relatively straightforward one to swap and much easier than a pull type...
- x 94
caspar
caspar
Had a look today and the clutch bites about half way through it's travel so don't think it needs adjusting.
Tried a gentle burn off as suggested but hasn't made any difference.
Not had a chance to look at the engine mounts yet.
The clutch shows no sign of slipping so will probably leave it for now and see how it goes for a while.
- x 94
i think in that case it will be either the thrust bearing seizeing up, and or burnning its way through the presure plate fingers,
i have just last week fitted a new clutch to my freind 2.0lt HDI Piscasoooo,
the thrust bearing had completly brocken up and the plastic centre had melted to the guide bush, and some of the presure plate finger tips were completly missing the others had folded completly over on themselves,
also only 4 ball bearings in sight,
regards malcolm
regards malcolm
- x 1446
A bad clutch ruins the car, yet changing it is almost always put off till the last moment, due to perceived cost (or real, in the case of some modern cars
). If the car is a keeper, and nothing else is arwy I would bang a new clutch in it - shouldn't be too dear for a 1.9D and not too arduous to fit - doable in a day DIY probably. We had a pretty duff clutch (judder and it must have had a groove in it, because you couldn't hold it on the clutch) in a Visa Special that we put up with for most of the time we had it - a new one would have transformed the drive (well, up to a point, it was a Visa Special after all
) - wish I had stuck a new one in. Would have been very easy on one of the (at least 2
) occasions I had to rebuild the front end after some unitentional modification took place
- x 94
