Xantia coolant bleed cap plug thing? - 540402 valve plug
romie
Unread post by romie »
Hey, anyone know if the little bleed cap that goes on a Xantia 1.9TD coolant system is only a genuine Citroen part or can I get them nice and cheap (and more conveniently), somewhere else?
Xantia, coolant system, bleed point in engine bay, cap sits on top.
Looks exactly like a schrader valve cap like you have on your car tyre valves. You know the little black plastic caps.
But this one has a rubber bit inside to make a good seal.
Guess what, Citroen said it's not sold separately and it looks like you have to buy a load of pipework to go with it!! B/
Then he mentioned that he thinks he know's what am on about and said he has a bucket of em with part No. 540402 and is described as a valve plug. And would cost me £0.50 each!!
Well they're quite a distance away and would like to source say 10 of em online. . so any ideas where?
Ta
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
spider
x 77
Unread post by spider »
It is more or less a valve cap with a rubber seal in it.
You might find the seal is the same (not sure!) as the one in a ZX / 306 / 205 heater hose, the plastic 'screw' type not the valve type, as this has a tiny seal fitted too, it might stay in the pipe but can be pulled out.
Usually with your problem its the complete pipe assembly, I know what you mean its the t-piece section. Normal cause of replacement though is when someone leans on it and it snaps off.
I'd suggest scrapyard to find one if practical.
Andy.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
PSA do list exactly the wheel valve cap as also a water circuit screw cap - it's on the turbo models...
romie
cheers. . In mean time am going to bung a tyre valve cap on and see what happens :p
hmm?
Yamaha R1 1999 26k
Clogzz
x 40
Unread post by Clogzz »
An aircraft engineer told me years ago that a proper tyre valve cap has a rubber seal.
The cap’s purpose is to keep the air in, while the valve’s seal is to allow pumping.
x 5674
They are only £1 from the dealer and have been redesigned and come in aluminumin now.
romie
hmm, cheers
Yamaha R1 1999 26k
