1.8-16v Xantia Running hot...
P616VKX
Unread post by P616VKX »
I know my radiator fans aren't working at all, but I'm sure it's not normal for my temperature gauge to be pointing at nearly 110 degrees when travelling at 70mph...
I've also noticed a little oil usage too.... About a litre a month.
Is this normal?
I haven't used the AC or anything to make the engine hot...
B564PLC - Red/Grey Renault 11 GTL 'Premiere'
VertVega
x 13
Re: 1.8-16v Xantia Running hot...
Unread post by VertVega »
P616VKX wrote:... my temperature gauge to be pointing at nearly 110 degrees when travelling at 70mph ...
This might be caused by another reason. From my experience (long time ago): Corrosion in minus cable of battery
and funny symptoms, one of them was the over temperature readings.
You can test fan motors by switching on air condition which should force both fans run even if the engine is cold.
I have recently added a thread in 'How-to' section:
--> Radiator fan motor removal
You might need it :wink:
VertVega
x 13
P616VKX wrote:... I've also noticed a little oil usage too.... About a litre a month.
Is this normal? ...
Usually mileage is more essential than the time. 1 lt sounds a lot.
As a first solution you can try motor flush and Forte is best for that.
P616VKX
Is this normal? ...
I've done 7,000 miles in 3 months, stuck in 3 litres of oil in that time.
VertVega
x 13
Generally speaking of engine oil consumption,
maximum permissible consumption (for a run-in engine) would be
0.5 liters per 600 miles (1000 km) for a petrol engine.
(It's 1 liter for a diesel model per 600 miles :roll: )
Clogzz
x 40
Unread post by Clogzz »
High temperature at speed isn’t a fan fault because there’s plenty of air blowing in from about 25 mph.
Unless it’s an indication fault, lack of coolant flow causes high temperatures at speed, possibly from a faulty thermostat.
If it gets too hot, it will be obvious when opening the bonnet.
If it consumes oil at normal temperatures, it will need a thicker oil.
P616VKX
Clogzz wrote:High temperature at speed isn’t a fan fault because there’s plenty of air blowing in from about 25 mph.
I think I'll have a go at the Thermostat and then look into the temperature sender... Probably due for a coolant flush anyway. I think the sender is a little duff as it never seems to read nothing... Apart from when the ignition is off, always reads 60...
