I have a 03 c5 Hdi ,the front seems very low between the front wheel arch and the tyre which is not much gap between them,i notice that the rear of the car when driving goes up quite a bit high and the front goes up very slightly not much though,when i get out of the car when the suspension goes down the front is very low also i have brand new mudflaps to fit on it ,I cant fit them on the front due to like an inch gap between the end of mudflap and the road therfore i didnt go ahead to fit them,past C5s that i have owned had a much bigger gap on the front wheel arch and tyre,please help,Last month i got new spheres fitted on the front and it has been the same gap since i have bought it 4 months ago
Cheers Gaz
CITROEB C5 SUSPENSION WOES !!!NOT MUCH GAP BETWEEN ARCH
gazzas c5
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
cachaciero
- x 9
Check the front height sensor, failure of these appears to be quite common and may explain your problem, the front rise when you select high suspension?.
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
gazzas c5
c5 suspension not much gap between arch and tyre
Hi the suspension rises with the buttons but goes back down quite close when set to normal height thanks.
dnsey
- x 19
gazzas c5
c5 suspension woes
Hi Dsney,How do i locate it and do the job?What was the problem with yours before u sorted it out>?many thanks Gaz
cachaciero
- x 9
Before you drill holes in the sensor check it's set correctly it clamps onto the front roll bar by slackening the clamp you should be able to move the arm and the suspension should rise or fall as appropriate, ONLY DO THIS ON RAMPS.
As to where it is exactly the Haynes BOL should show you that, somebody might like to confirm that.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
dnsey
- x 19
My reasoning is that if nothing else has changed, the clamp position should still be correct, and any simple problem will be down to the sensor.
It's a matter of preference - personally, if in doubt, I'd swap front and rear sensors as a check (or substitute a standard pot for the sensor to test the effect) before upsetting the clamp position.
FWIW, to clean the sensor track, unbolt the sensor unit from the clamp (leaving the clamp in place), and unclip the 'dogbone'. Visualise the track and wiper within the sensor body and carefully drill a small hole in the plastic body where it will clear them. Inject some switch cleaner - the sort that won't attack plastics - and move the sensor through its full travel at least 20 times. Seal the hole with hotmelt glue or WHY. While you're at it, squirt the external connectors too.
Refit and try!
Refit and try!
cachaciero
- x 9
Not an unreasonable position but the O/P has had the car for 4 months and it has been like that since he got it, trouble is he / we don't know what was done before he got it, theres lotsa cowboys out therednsey wrote:My reasoning is that if nothing else has changed, the clamp position should still be correct, and any simple problem will be down to the sensor.
Changing the clamp position is no big deal, do like the idea of a seperate pot on a couple of feet of wire one could play with height from the side rather than underneath the car
A lexia makes it even easier you can adjust the height just by writing in new calibration values
cachaciero.
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
