Hi Guys,
Up to my elbows in grease and oil.
As is the keyboard now.
Does anyone have access to the following information?
Torque Values for:-
Injectors into Cylinder Head
Glow Plugs into Cylinder Head
on a S1 Xantia 1.9TD SX.
It seems my running problem may have been down to a lone glow plug that was dead. Have yet to get it back together and check the waxstat but it is definitely NOT the injectors.
Hoping someone can almost answer the values of the top of their head!
Many thanks, Rhothgar
Torque Settings for S1 Xant Diesel Injectors and Glow Plugs
Rhothgar
- (Donor 2026)
- x 222
spider
- x 77
I've never used a torque wrench for tightening these and never had any problems.
Anyway here's the tech data I have to hand for an XUD (it does not list different values for XUDT nor for 1.8 / 1.9), I assume its accurate:
Glowplugs: 22Nm / 16 lbf ft
Injector (Bosch): 90 Nm / 66 lbf ft
Injector (Lucas): 130 Nm / 96 lbf ft
Injector pipe union nuts: 20 Nm / 15 lbf ft
Hope that helps.
Hope that helps.
Andy.
- x 8459
When you have disturbed injectors Roger, it's vital to renew the firewashers and copper sealing washers.
A duff/deformed/upside down firewasher can upset the injector spray pattern and reusing the copper washers can encourage leaks.
The glowplugs won't be the cause of running issues unless the body and tip is very badly damaged. Glowplugs only help the engine to start...
Rhothgar
- (Donor 2026)
- x 222
spider
- x 77
Rhothgar
- (Donor 2026)
- x 222
spider
- x 77
I did sell it (
) but not on Ebay no. It was a genuine early (for the UK, I know they were sold elsewhere a few years before) D-Turbo not the strange later MardiGra one so had the proper sports seats / factory tacho (GTi Style instrument panel) vacuum sunroof (worked and no leaks or noise)
I'm still missing it.
Andy.
