Isothermal padding for undertray or not
boristhespie
x 4
Unread post by boristhespie »
Found supplier of new undertray and they offer ones fitted with isothermal mats and without. I suspect the matring is to protect agains heat hitting the tray. Thing is costs more.
Is it necessary?
C'est pas possible!
x 1955
Unread post by Paul-R »
There isn't the same heat from a diesel engine as a petrol engine (except around the turbo) so this may not be the real reason. I suspect the padding is there to reduce noise.
Clogzz
x 40
Unread post by Clogzz »
Not necessary and that supplier is just a snake oil merchant.
A non-genuine tray may not fit easily and there’s not much heat under the engine.
The padding will soak up oil and become heavy, then fall out.
boristhespie
x 4
I ordered one without. Mistake?
C'est pas possible!
x 5688
How much?
I may be needing one to as mine is looking rather sorry for itself.
boristhespie
x 4
Pm'd you
C'est pas possible!
wright
Unread post by wright »
is it a secret how much?
02 C5 2.0 hdi 110
boristhespie
x 4
£52
C'est pas possible!
Kowalski
Unread post by Kowalski »
C5 ? Xantia? 1.9 TDI ? HDI ?
My Xantia which still had its undertray was a 1.9 TD and had foam padding on the insider, the C5 is a 2.0 16v and it's undertray was replaced before my ownership but the undertray fitted has silver foil on the inside...
Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
Kowalski wrote:but the undertray fitted has silver foil on the inside...
How do you think the French warm their croissants in the morning? Microwave?
